receiver yamaha 595 + 3 power peavy cs800x
Muchachines me llegaron estos chiches, son algo antiguos,tiene más referencias...
[img]http://img.canuckaudiomart.com/uploads/large/252261-yamaha_rxv595a_receiver_dolby_dts_cinema_dsp_digital_optical.jpg[/img]
Receiver Yamaha VX-595.
Minimum RMS Output Power per Channel 8 ohms, 20Hz to 20kHz, 0.019% THD = 80W 6 ohms, 20Hz to 20kHz, 0.038% THD = 90W
Dynamic Power per Channel (IHF)8/6/4/2/ ohms = 120/140/180/200W
Power Bandwidth 8 ohms, 40W, 0.038% THD = 10Hz to 50kHz
Damping Factor (8 ohms, 20 Hz-20 kHz) 240 or more
Input Sensitivity/ Impedance PHONO MM = 2.5mV/47k-ohms CD etc = 150mV/47k-ohms
Maximum Input Signal Level (1kHz, 0.003% THD)PHONO MM = 115mV
Output Level/ Impedance REC OUT = 150mV/470 ohms
Headphone Jack Rated Output/Impedance 0.019% THD, RL = 8 ohms = 0.3V/680 ohms
Frequency Response (20Hz to 20kHz)CD etc = 0+/-0.5dB
RIAA Equalization Deviation (20Hz to 20kHz)PHONO MM = 0+/-0.3dB
Total Harmonic Distortion (20Hz to 20kHz)PHONO MM to REC OUT (3V) = 0.003% CD etc. to SP OUT (40W/8 ohms) = 0.008%
Intermodulation Distortion CD etc. (Rated Output 8 ohms) = 0.01%
CD Player
Signal-to-Noise Ratio (IHF-A-Network)PHONO MM (5mV Input Shorted) = 88dB CD etc. (Shorted) = 110dB
Specifications
Residual Noise (IHF-A-Network) CD DIRECT AMP SW ON = 35uV PURE DIRECT SW ON = 90uv
Channel Separation (1 kHz, Vol.-30dB)CD etc. (Input 5.1k ohms Terminated, 1kHz/10kHz = 65dB/50dB
Tone Control Characteristics BASS Boost/cut = +/-10dB (20Hz) Turnover Frequency = 350Hz TREBLE Boost/cut = +/-10dB (20kHz) Turnover Frequency = 3.5kHz
Continuous Loudness Control 30dB (1kHz)(Level related equalization)
Gain Tracking Error (0-60dB)
Turning Range 530 70 1,710kHZ
Usable Sensitivity 100uV/m
Selectivity 32dB
Image Response Ratio 40dB
Spurious Response Ratio 50dB
Harmonic Distortion (400Hz) 0.3%
Tuning Range 87.5 to 107.9MHz
50dB Quieting Sensitivity (IHF, 75 ohms)Mono = 1.55uV (15.1dBf) Stereo = 21uV (37.7dBf)
If Response Ratio 80dB
AM Suppression Ratio 55dB
Capture Ratio 1.5dB
Alternate Channel Selectivity 85dB
Stereo Separation (1kHz) = 50dB
Power Supply AC120V, 60Hz
Power Consumption 190W
AC Outlets Switched x 2 = 100W max.
Dimensions (W * h * D) = 435 * 146 * 386mm (17-1/8" * 5-3/4" * 15-5/16")
Weight 9.5kg (20lbs 10z.)
y 3 monstruos de estos:
[img]http://medias.audiofanzine.com/images/normal/peavey-cs-800-22022.jpg[/img]
[img]http://medias.audiofanzine.com/images/normal/peavey-cs-800-12296.jpg[/img]
http://peavey.com/media/pdf/manuals/80300991.pdf.
al receiver solo le falta un perilla. :mad:
https://www.hifichile.cl/topic/13798-receiver-yamaha-595-3-power-peavy-cs800x/
Son pa tu home cinema??!! :o
Shuuuu
Yamaha como pre y Peavy como power de frontales, surround y central se me ocurre
Digitalizándome!
[quote name='Tomhate' date='14 April 2015 - 12:27 PM' timestamp='1429025259' post='292375']
Shuuuu
no, me llegaron. y quiero saber más de ellos para posible ventolera queridi..
Noooooooooo.... son remalos, tienden a hacer combustión espontánea, si quiere, me los pasa y yo me desago de ellos de forma adecuada... :blush:
TPA
