Onda matrix, pildora azul o la pildora roja... que mier.... es esto?
http://highend-electronics.com/products/synergistic-research-pht-phono-transducer
You’ll never forget your first PHT Experience:
To get started with PHT simply apply 1 micro-transduer, Type ‘I” or Type ‘S’ to the top of your phono cartridge or head-shell for an immediate and dramatic transformation. Improvemenets include a lower noise floor, increased resolution and improved bass extension with increased air and soundstaging.
Available in two distinct strains:
Type ‘I’ PHT is called Blue Velvet. Its sound is ethereal, lush and holographic. You’ll definitely ‘trip out’ the first time you experience your system on Blue Velvet!
Type ‘S’ PHT is called Purple Haze. Its sound is focused, precise and musical. The first time you listen to your favorite records on Purple Haze you’ll hear information you didn’t know existed, presented in a precise musical way.
Owning both Blue Velvet and Purple Haze PHTs is like having two state-of-the-art cartridges costing thousands of dollars each, for the price of a good stylus pressure gauge!
[img]http://www.synergisticresearch.com/sophic/wp-content/uploads/2014/10/PHT-Blue-Velvet-632.jpg[/img]
Solo 199 dolares...
Editado por hectori
https://www.hifichile.cl/topic/15254-snake-oil-vinilero/
Me están hueveando... sólo con ponerlo encima, esa huevá mágica, armada por vírgenes vestales, me mejora dramáticamente el sonido? y qué hace? cómo funciona? genera ondas kirlianas que inducen sobre los embobinados del cartucho? con qué energia? acaso con una cadena de oración coordinada desde fábrica?
https://www.hifichile.cl/topic/15254-snake-oil-vinilero/#findComment-321927
Biker anatema, arderás en el infierno escuchando reggaeton en puros muteki por falto de fe, que es justamente el ingrediente principal para que funcione :lol::lol::lol:
Solo con fe ciega (y sorda) escucharás abismantes diferencias :zippytanax:
https://www.hifichile.cl/topic/15254-snake-oil-vinilero/#findComment-321931
¿Y si le ponemos una monedita? Tengo de 1 peso, de 5 y de 10 listas...
https://www.hifichile.cl/topic/15254-snake-oil-vinilero/#findComment-321964
