SONY STR-AV920
nelson maldonado
Sony STR-AV920
AM/FM Stereo Receiver
add a review add a review
sony str-av920 audio video receiver
Sony STR-AV920
Specifications
Tuning range: FM, MW
Power output: 100 watts per channel into 8Ω (stereo)
Surround output: 100W (front), 10W (rear)
Frequency response: 10Hz to 70kHz
Total harmonic distortion: 0.03%
Damping factor: 50
Input sensitivity: 2.5mV (MM), 150mV (line)
Signal to noise ratio: 87dB (MM), 105dB (line)
Output: 150mV (line)
Speaker load impedance: 4Ω to 16Ω
Video Connections: composite
Dimensions: 430 x 135 x 350mm
Weight: 10.2kg
Accessories: RM-U201 remote control
Year: 1990
SOURCE: https://www.hifiengine.com/manual_library/sony/str-av920.shtml
Este es un receiver AV Que esta mas destinado para amplificar películas que música. Por lo tanto, si quieres un receiver para música, usa un sterep.
hace 8 horas, AEZ-46 dijo:
:rap:
