COCKTAIL AUDIO EN STOCK!
EN STOCK STREAMERS COCKTAIL AUDIO, SOMOS REPRESENTANTES OFICIALES EN CHILE, IMPORTADORES DIRECTOS DESDE COREA
COCKTAIL AUDIO N25 $1.290.000
명칭
  • Hardware Specifications
  • fea_icon.pngEquipped with a high-performance dual core ARM Cortex A9 processor running at 1.0Ghz
  • fea_icon.pngESS ES9018K2M Sabre32 Reference DAC chip for D-A conversion
  • fea_icon.pngUSB Audio Class 2.0 output for connection to external USB DACs
  • fea_icon.pngIsolated power supply circuit design, separate for digital and analogue sections, to remove electrical noise
  • fea_icon.png4.6” TFT LCD screen (800 x 320 pixels) for intuitive GUI
  • fea_icon.pngDAB+/FM tuner built-in
  • fea_icon.pngHDMI ARC input built-in
  • fea_icon.pngHDMI output for connecting external screens, such as a TV as the GUI screen, or for audio signal output
  • fea_icon.pngBluetooth receiver built-in, with support for SBC, AAC, aptX, aptX LL, aptX HD
  • fea_icon.pngUSB Audio Class 2.0 input
  • fea_icon.pngHigh quality analogue output terminals
  • fea_icon.pngDigital output (1 x Coaxial, 1 x Toslink)
  • fea_icon.pngDigital input (1 x Coaxial, 1 x Toslink)
  • fea_icon.pngUSB 3.0 high speed host port x2, on the rear panel
  • fea_icon.pngUSB 2.0 host port x1, on the front panel
  • fea_icon.pngGiga Fast Ethernet(10/100/1000Mbps) built-in
  • fea_icon.pngFive (5) custom keys on the front panel for DAB+ or FM radio presets
  • fea_icon.pngPrecisely CNC-machined aluminum front panel and robust rigid steel chassis
COCKTAIL AUDIO X35 $2.190.000
x35
  • Features of Hardware and Engineering
  • fea_icon.pngEquipped with high-performance Dual Core ARM Cortex A9 processor running at 1.0Ghz
  • fea_icon.pngESS ES9018K2M Sabre³² Reference DAC built-in
  • fea_icon.pngCombined with two(2) separate high-performance Class D Amplifiers for left and right with total 200 watts
  • fea_icon.pngIsolated power source circuit design for digital and analogue parts
  • fea_icon.pngToroidal transformer to minimize idle noise
  • fea_icon.pngHigh speed optical disk drive for quick CD ripping
  • fea_icon.png7 inch TFT LCD(1024 x 600 pixels) screen for intuitive GUI
  • fea_icon.pngDAB+/FM Tuner built-in
  • fea_icon.pngSupport up to 8TB(Tera Bytes) storage like 3.5"/2.5" hard disk or SSD
  • fea_icon.pngRugged chassis contruction with 13mm thickness aluminum front and knobs with CNC cutting
  • fea_icon.pngHDMI Out connector for using an external screen like TV as its GUI screen
  • Like 2
Enlace al mensaje
