FLAGSHIP 11 Publicado Mayo 16 Share Publicado Mayo 16 View Advert Power ATC P2 + Pre ATC CA2 Con el permiso de la Administracion, y agradeciendo desde ya el Espacio, pongo a la venta este Pack Ingles: -Pre ATC CA2 -Power ATC P2 En perfecto estado con sus Cajas y controles remotos No necesitan mayor presentacion. P2 – Dual-Mono Power Amplifier Overview Upgrading from the P1 power amp, the P2 adds a much larger power supply and additional output MOSFETs to double power to 300W per channel. It is the ideal solution to drive speakers in larger rooms and/or when a loudspeaker presents a difficult load and will provide an effortless, musical presentation under these demanding conditions. Like the smaller P1, the combination of exceptional resolution and neutral fidelity allows the quality of the original recording to shine through whilst also offering outstanding compatibility with a wide range of partnering equipment. Features 300W per channel – ideal for larger rooms and/or challenging loudspeaker loads. Dual-mono design delivers full power simultaneously from both channels, with minimal crosstalk. Balanced and un-balanced inputs, plus un-balanced ‘link’ outputs. Grounded source class A/B output stage circuits as found in ATC’s renowned active loudspeakers. Wide bandwidth, low distortion and high dynamic range ensure tonal accuracy and perfectly timed transients. Gain matched to smaller 150W P1 enabling bi-amp compatibility. Neutral fidelity ensures excellent system compatibility. Hand built in the UK and supported by a 6 year warranty. Max Continuous Output Power: >300W (1% THD, 8 ohms, both channels driven) Input Sensitivity: 2V (ref. 150W out) Frequency Response: <2Hz – >400kHz (-3dB) S+N/N Ratio: >115dB (ref 150W, IEC ‘A’) Crosstalk : >100dB (10Hz – 20kHz) THD: <0.002% / -95dB (8 ohms, 1kHz, 1dB below full power) Analogue Line Inputs: 1 x stereo pair female XLR (balanced), 1 x stereo pair RCA/Phono (unbalanced) Output ‘Link’: 1 x stereo pair RCA/Phono (unbalanced) Dimensions: 142 x 453 x 338mm / 5.6 x 17.8 x 13.3 inches (H x W x D inc. terminals) Weight: 23.35kg / 51.37lbs CA2 – Stereo Pre-Amplifier Overview Given ATC’s history manufacturing active loudspeakers, a partnering preamplifier was a logical step and our first preamp, the SCA2 was released in 1996. The CA2 – a simpler design yet still offering exceptional performance – is derived from the ‘high-end’ SCA2 and maintains its exceptional performance, but with fewer features. It is equally adept at driving active loudspeakers as paired with one of ATCs power amplifiers and a wide range of inputs and outputs ensure outstanding compatibility with a very wide range of partnering equipment. Features Discrete class-A low-noise circuitry evolved from high-end SCA2 preamp. MC/MM RIAA Phono Stage with adjustable gain/loading. High-Performance Headphone Amplifier. 5 x stereo RCA/Phono inputs. IR Remote Control. Hand built in the UK & covered by a 6–year warranty. Frequency Response: D.C. – >500kHz (-3dB) THD: < 0.0005% / -106dB (1kHz, 1V, 600 ohms) S+N/N Ratio: >108dB (IEC ‘A’) Crosstalk: >90dB (10Hz – 20kHz) Input sensitivity: 150mV (re. 1V out) Maximum Output Level: 7.5V r.m.s. (600 ohms) Analogue Preamp Outputs: 2 x stereo pair RCA/Phono, 1 x stereo pair male XLR (all unbalanced) Headphone Amp Output: 1 x via 6.35mm jack Analogue Tape Output: 1 x stereo pair RCA/Phono Analogue Line Inputs: 5 x stereo pairs RCA/Phono RIAA Phono Input:: 1 x pair via RCA/Phono. MC/MM with adjustable gain & loading. Dimensions: 94 x 449 x 330mm / 3.7 x 17.7 x 13.0 inches (H x W x D inc. chassis connectors) Weight: 6kg / 13.2lbs Advertiser FLAGSHIP Date 15/05/23 Price $ 4.600.000,00 Category Audio, video, el hobby en general Enlace al comentario Compartir en otros sitios More sharing options...
